JRE 1.1.8 не ставится из-за compat3x в FreeBSD 6.2
mallory
Сообщение mallory »
Установка JRE в FreeBSD 6.2:
#make
===>   NOTICE:
This port is deprecated; you may wish to reconsider installing it:
For obsolete version of jdk; depends on forbidden compat3x package.
It is scheduled to be removed on or after 2007-08-22.
===>  Vulnerability check disabled, database not found
=> jre1.1.8i_ELF.V1999-11-9.tar.gz doesn't seem to exist in /usr/ports/distfiles/.
=> Attempting to fetch from ftp://ftp.se.freebsd.org/pub/FreeBSD/JDK/.
jre1.1.8i_ELF.V1999-11-9.tar.gz               100% of 4741 kB   30 kBps 00m00s
===>  Extracting for jre-1.1.8
=> MD5 Checksum OK for jre1.1.8i_ELF.V1999-11-9.tar.gz.
=> SHA256 Checksum OK for jre1.1.8i_ELF.V1999-11-9.tar.gz.
===>  Patching for jre-1.1.8
===>   jre-1.1.8 depends on shared library: c.3 - not found
===>    Verifying install for c.3 in /usr/ports/misc/compat3x
===>  compat3x-i386-5.0.20020925 is forbidden: "FreeBSD-SA-03:05.xdr, FreeBSD-SA-03:08.realpath  - not fixed / no lib available".
*** Error code 1
Stop in /usr/ports/misc/compat3x.
*** Error code 1
Stop in /usr/ports/java/jre.
Что делать?
Jay
Сообщение Jay »
# cd /usr/ports/java/diablo-jre15/ && make install clean
Хм, интересно, а как бы смотрелась эта крошка, если ей перерезать горло? Мне кажется, неплохо...
